Engine Tappet Valve Clearance
  • dsj1979
  • dsj1979s Avatar Themenstarter
01 Aug. 2015 00:37
Hi,
I need to check the tappets / valve clearances as part of the service. I have a manual which states:
Inlet 0.30mm
Exhaust 0.20mm
Normally the exhaust clearance is bigger than the inlet. Has the manual made a mistake and it should be the other way around?
Thanks,
Daniel
  • saviemeke
  • saviemekes Avatar
Re: Engine Tappet Valve Clearance
02 Aug. 2015 18:19
Hi Daniel,
What type of motor do you have ? The clearence for my motor a 2.5 td is 0.5 inlet and 0.5 exhaust.
  • dsj1979
02 Aug. 2015 19:17
It's a 2.5d. I have just set them at 0.20 inlet and 0.30 exhaust. Seems okay... :)
Ladezeit der Seite: 0.339 Sekunden
