Antwort: Increase the output 2.5TD engine.
Themenhistorie von: Increase the output 2.5TD engine.
Very impressive job you have done on your car Gerard.
I often look at your site for tips and ideas :daumen2:
I've been thinking if I will gladly discuss the challenge, in order to replace the stick.
The system will work, however the good tuning without measurement tool will be very tricky.
Our camper pulls pretty good, so I decided not to replace the stick for the time being.
Over the next few years, I have enough other work to our camper to do!
See my Blog on hobby600.wordpress.com
If there is someone who wants to buy this stick. I can arrange it all. The freight on the stick if I buy it in Sweden is part of € 90. So there will be extra shipping to Germany or wherever you want sent ... It has the same function as DT piston. Maybe even better. And the price difference is huge.
:543: :1723:
Then are probably € 90 a little cheaper :laugh:
KN airfilter... you can find cheaper than that.
On the Dutch marktplace site this advertisement was found.
Marktplaats
I asked for more info, they asked for a new pin, including mounting 550€ :woohoo:
And they give teh advice to use a KN airfilter, cost 120€ :woohoo:
This stick can be ordered from www.dieselmeken.se/
Cost 800sek (around €90)
Only works on a turbocharged engine.
More power to the Kult-Wohnmobil :daumen2:
I've found a cheap stick..
www.brickwerks.co.uk/index.php/ve-boost-pin.html
But it looks just like the original. I'll make some calls tomorrow and sort this out.
Hello.
The stick is available here. www.autostable.se/motortrim/optimeringsl...ar/dt-piston-1833317 Very expensive unfortunately.. €370 :1435:
Hi,
a friend of mine pointed out to me on this ad on the Dutch market place
Marktplaats
I write them for more information, when I know more,i will write it here.
Them in the picture cost 800sek (90eur)
Availability, I have not received any reply from him.
The same type of stick is also mounted in for example wolksvagen.
The stick is originally from Bosch VP pumps for industrial use.
