Antwort: Engine Tappet Valve Clearance
Themenhistorie von: Engine Tappet Valve Clearance
It's a 2.5d. I have just set them at 0.20 inlet and 0.30 exhaust. Seems okay... :)
Hi Daniel,
What type of motor do you have ? The clearence for my motor a 2.5 td is 0.5 inlet and 0.5 exhaust.
Hi,
I need to check the tappets / valve clearances as part of the service. I have a manual which states:
Inlet 0.30mm
Exhaust 0.20mm
Normally the exhaust clearance is bigger than the inlet. Has the manual made a mistake and it should be the other way around?
Thanks,
Daniel
Ladezeit der Seite: 0.274 Sekunden
