Engine Tappet Valve Clearance
- dsj1979
01 Aug. 2015 00:37
Hi,
I need to check the tappets / valve clearances as part of the service. I have a manual which states:
Inlet 0.30mm
Exhaust 0.20mm
Normally the exhaust clearance is bigger than the inlet. Has the manual made a mistake and it should be the other way around?
Thanks,
Daniel
Inlet 0.30mm
Exhaust 0.20mm
Thanks,
Daniel
Antworten zu dsj1979
- saviemeke
Re: Engine Tappet Valve Clearance
02 Aug. 2015 18:19
Hi Daniel,
What type of motor do you have ? The clearence for my motor a 2.5 td is 0.5 inlet and 0.5 exhaust.
Antworten zu saviemeke
Ladezeit der Seite: 1.194 Sekunden
