Body Repair
  • Jankos
  • Jankoss Avatar Themenstarter
Re: Aw: Body Repair
12 Juni 2010 09:32
New register plate is ordered, but not yet received (in finland we can't buy plates like in germany)
Family Koskinen from Jokioinen, Finland.
Photos of our motorhome
  • Jankos
Re: Aw: Body Repair
14 Juni 2010 19:23
Today I made some painting. It didn't go well at all. It looks good if you are far enough :1435:
Also I installed DRL (tagfahrlicht) and found nice place for those.
No more big needs before trip! Just washing and test drives. :drive1:
  • Jankos
Re: Aw: Body Repair
25 Aug. 2010 19:40
HELLO!
I find out what regulations are for a DRL lights!
ECE R87 is for independent light and ECE-R48 is specificating how these should work.
There is mention:
6.19.7.2. If the distance between the front direction-indicator lamp and the daytime running
lamp is equal or less than 40 mm, the electrical connections of the daytime
running lamp on the relevant side of the vehicle may be such that either:
(a) It is switched OFF; or
(b) Its luminous intensity is reduced during the entire period (both ON and OFF
cycle) of activation of a front direction-indicator lamp.
This is defining that on my installation case (and some others too) DRL must be shutdown when direction indication lamp is blinking.
So I must connect wire from direction indicator lamp with a diode to shutdown line and also add a diode to normal shutdown line.
With this connection I'm sure that blinking is easily seen...
Re: Aw: Body Repair
25 Aug. 2010 20:16
running lamp on the relevant side of the vehicle may be such that either:...
Hallo Janni,
what you find :evil:
In Germany, there ist no regulation for the distance between DRL lights and front direction-indicator lamp! Look here on page 94 you see the regulations for DRL lights. .. or here . And Germany is allso in the EU :evil:
  • Jankos
Re: Aw: Body Repair
25 Aug. 2010 20:32 - 25 Aug. 2010 20:35
Lollo_C schrieb:
Hallo Janni,
BTW, your regulation is revision 4, newest one is revision 7... There might be some changes :P
In english it's here www.unece.org/trans/main/wp29/wp29regs/r48r6e.pdf
Yes, I know it would take couple more years to find person who can translate this one from english to deutsch :D
Letzte Änderung: 25 Aug. 2010 20:35 von Jankos.
Re: Aw: Body Repair
25 Aug. 2010 20:47
it ist the official Version by the german traffic ministry :1563:
... and I think, there is a inventory protection for old vehicles :drive1:
  • Jankos
Re: Aw: Body Repair
25 Aug. 2010 20:59 - 25 Aug. 2010 21:00
At least you even got any version on your own language.
Here in Finland there is not any official or any unofficial information of DRL things. I have asked those things with inspectors and they are just saying that they don't know what is right solution with these.
Letzte Änderung: 25 Aug. 2010 21:00 von Jankos.
Ladezeit der Seite: 0.337 Sekunden
