ladegerat und bord accu 15 volt ?
  • hurbie
  • hurbies Avatar Themenstarter
  • Neuling (ohne Vorstellung)
07 Nov. 2010 18:24
hallo allen,
when i put the 220 volt input on the camper, the batterycharger puts 15 volt on the household batterie , i can hear the battry start to boil !!
it's the original charger , the bordcontrol says the current is only 11.5 volt's , but if i messure the battery there's more then 15 volt on it .
can somebody help ?
  • berny
  • bernys Avatar
  • Hobby 600-II(Linie_C)
Re: Aw: ladegerat und bord accu 15 volt ?
07 Nov. 2010 21:17
The normal Battery-Charge Volt are 14,4.
(Normaly between 13,8 and 14,4)
If the Volt are higher, the batterycharger is broken.
If the Battery is to hot, maybe it is also broken, oxyhydrogen will be produced.
Be carfully, this steam is high explosiv!
  • hurbie
07 Nov. 2010 21:24
thanks ,
i think the charger is not regulated very well by the BCC , i read in another thread that there's a relay in the bcc witch cut's the charging current.
08 Nov. 2010 16:20
Hello Hurbie,
a control circuit which switches about the relay r1 the loading process of the battery is on the board. There are Trimmer to the adjusting of the switch thresholds. I have belonged that this has already done somebody. I would dare there personally not in it, but insert rather immediately a modern battery charger with identity line IUoU like Hans.
Best regards
  • hurbie
08 Nov. 2010 18:35
thanks for the replays sofar ,
you can answer in german (reading is not a problem for me , writing is )
groeten gerben
