Help with electrical system problem
  • checkmate
  • checkmates Avatar Themenstarter
01 Juni 2015 22:33
:2172:
Hello!
We're having a problem with the electric system and hope somebody can help. The thing is for the last 5 days, at the end of the day the electric power seems to fail. The light goes on and off at moments and some hours later it works fine as usual. The convertor to 220V works perfectly.
Today the problem has been bigger, and we couldn't turn on the electric system because it turns on and off intermitently.
We've got two solar plaques and they seem to be working and loading correctly as we're having a lot of sun in here.
Any ideas of what the problem can be??
Thanks a lot for your help!
:daumen2:
Re: Help with electrical system problem
01 Juni 2015 22:49
Hello Javi,
I think that the problem is in the wiring from the charging block (under the seat) to the BCC on the dashboard. ....or in the board of the BCC. Since probably only helps to take a diagram and measure. Look at the Pictures from the Electric too.
Folgende Benutzer bedankten sich: checkmate
  • saviemeke
  • saviemekes Avatar
02 Juni 2015 21:36
Hallo Javi,
I think, the plug connectors between the wiring will give some problems. they can oxidize whereby the connection will lost.
  • checkmate
03 Juni 2015 13:21
Thanks a lot Wilfried and Gérard for the help and the pictures. We'll try to fix the problem and report you back with the outcome!
Ladezeit der Seite: 0.316 Sekunden
