Antwort: Proplem whit E-controlpanel
Themenhistorie von: Proplem whit E-controlpanel
Hallo Esa,
you would not find a new board anywhere. Also used boards are very rare.
If you need only a relay, then I can remove it from a defective board. But usually the conductor paths are defective.
I would chance in such a case to a modern charger. See this article
The meters are also no longer available
Hi,
I have proplem whit my controlpanel,there is some relay what make very much noise.
I thik it relay R1 (Laudung)
Controlpanel type 7800 and card serialnumper is : Steuer H05TNR15341 B14326
I allso want change those old volt and Amphermeter, because they dont work.
Here is some fotos, i so sorry but i cant understand Germany.
Nice summer to all of you .
Best Regards
Esa Piispa
Finland
Ladezeit der Seite: 0.324 Sekunden
