Fridge and water heater
- dsj1979
19 Dez. 2013 20:21
Hi,
A couple of questions:
1) When the fridge is on the coldest setting is the knob turned completely clockwise or anti-clockwise?
2) When on mains 240v does the water heater automatically heat the water up or do you need to do anything with the thermostat switch?
Thanks,
Daniel
Thanks,
Daniel
Antworten zu dsj1979
- saviemeke
Re: Fridge and water heater
19 Dez. 2013 21:23
Hi Daniel,
So far I know shout you turn the knob clockwise for the coldest settings of your fridge.
The boiler is, in our camper, a gaz-boiler in combine with 12 V, so why do you think your water heater is working with 230V ?
To heat the water you must have gaz and switch the boiler on, on the thermostat, afther that you should use the thermostat for the wanted temperature height.
Antworten zu saviemeke
- dsj1979
19 Dez. 2013 21:42
Clockwise, excellent many thanks.
Ah, for some reason I thought the water heater heated the water when it was plugged into mains 240v power. Ok, that makes sense then why it didn't seem to heat the water when I connected to mains 240v power.
Thanks,
Daniel
Thanks,
Daniel
26 Dez. 2013 00:01
hi Daniel
before asking more questions in the forum, you should even look in the download section and download the manuals.
There is also one in English.
Hobby 600 - Operational Manual
- dsj1979
26 Dez. 2013 09:55
I've looked at every download there is. Websites can be automatically translated, most of the downloads can't unfortunately so I often see pretty pictures.... but have no idea what is being said. The English manual is useful.
As for the 240v question, I'd had a long day working on the Hobby and my mind went :1435:
