Antwort: Fridge and water heater
Themenhistorie von: Fridge and water heater
I've looked at every download there is. Websites can be automatically translated, most of the downloads can't unfortunately so I often see pretty pictures.... but have no idea what is being said. The English manual is useful.
As for the 240v question, I'd had a long day working on the Hobby and my mind went :1435:
hi Daniel
before asking more questions in the forum, you should even look in the download section and download the manuals.
There is also one in English.
Hobby 600 - Operational Manual
Clockwise, excellent many thanks.
Ah, for some reason I thought the water heater heated the water when it was plugged into mains 240v power. Ok, that makes sense then why it didn't seem to heat the water when I connected to mains 240v power.
Thanks,
Daniel
Hi Daniel,
So far I know shout you turn the knob clockwise for the coldest settings of your fridge.
The boiler is, in our camper, a gaz-boiler in combine with 12 V, so why do you think your water heater is working with 230V ?
To heat the water you must have gaz and switch the boiler on, on the thermostat, afther that you should use the thermostat for the wanted temperature height.
Hi,
A couple of questions:
1) When the fridge is on the coldest setting is the knob turned completely clockwise or anti-clockwise?
2) When on mains 240v does the water heater automatically heat the water up or do you need to do anything with the thermostat switch?
Thanks,
Daniel
