50mb to 30mb
- dsj1979
50mb to 30mb
19 Aug. 2014 22:02
Hi,
I fitted a LPG tank under the motorhome (though I haven't been able to fill it up yet as I started dealing with the bodywork!). Anyway, I fitted a 30mb regulator as the fridge is now all electric (compressor), at some point the hob will be replaced with a smev 9222 and an oven which will be set up for 30mb. I've ordered 30mb jets for the truma 3002 which just leaves the truma water heater.
Has anyone run the water heater on 30mb? Or, if it needs converting from 50mb to 30mb, do you know what needs to be changed? I've googled lots but can't find an answer.
Thanks,
Daniel
Thanks,
Daniel
Antworten zu dsj1979
Re: 50mb to 30mb
20 Aug. 2014 00:16
Hi Daniel
have a look on this Website: www.gasprofi24.de/gas-und-technik/regler...r-zu-30-mbar/a-7289/
God luck.
God luck.
- dsj1979
Re: 50mb to 30mb
20 Aug. 2014 19:46
I don't think I wrote the question too clearly. My hobby was running all equipment at 50mb. I am going to put other equipment in which will run at 30mb i.e. new oven and grill. I decided I don't want to have two regulators 50mb and 30mb so I am converting everything to run at 30mb. The Truma 3002 is easy just requiring new jets.
The question is, what parts do I need to convert the ultrastore to run at 30mb? I've seen a ultrastore 30mb gas solenoid as per ebay link, but I don't know if that is for a mk1 ultrastore. And if it is, is this the only thing needed for the ultrastore to run on the new 30mb system?
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem...e=ADME:X:AAQ:GB:1123
Re: 50mb to 30mb
20 Aug. 2014 20:21Hallo Hans,alter_hollaender schrieb: haben wir nicht 50 mBar, da nütz doch kein Regler von 50 nach 30 mBar, oder liege ich da falsch?
Du liegst da schon richtig. Die alten Fahrzeuge haben alle 50 mbar. Man kann an diesen Anlagen neue Geräte mit 30mbar betreiben, wenn man einen Druckminderer von 50mbar>>30mbar vor baut. Dann muss allerdings vor jedes 30mbar Gerät soch ein Druckminderer (Der von Horst verlinkte Regler ist in Fahrzeugen nicht zulässig!)
Ich habe Daniel aber so verstanden, dass er die komplette Gasanlage auf 30mbar umgerüstet hat und jetzt nur noch einen passenden "Brenner" für den alten Boiler sucht. Bei dieser FRage kann ich ihm aber leider nicht helfen; keine Erfahrung!
Ladezeit der Seite: 0.343 Sekunden
